This is most probably a bug, and I just wanted to report it. If this is the wrong way to report a bug, please tell me the correct way!
By the way, I'm using NetAdvantage 10.2 Win CLR2x
To reproduce the bug:
Now, start the program, and the buttons size will be messed up, because of the presence of the elementhost.
A work around is to put a transparent (or other color) backcolor on the elementhost, then for some reason, the sizeing of the button on the first tab will be ok.
This is ONLY a problem with sizing Controls on OTHER tabs in the sabe tabcontrol. If I put sizing Controls on the same tab, or just in some other container (other then ultratabcontrol) all works well.
I know I'm not running the latest version of NetAdvantage. Could someone check if this is still a problem in the latest version?
Regards Andreas
Hi;
Thank you for the feedback, please let me know when if you still need help on this.
Hi, and thank you for the answer.
I haven't had time to install the latest version yet, but since you couldn't reproduce the problem I guess the new version will solve it.
Hi Andreas,
I wanted to know if you were able to solve your issue based on these suggestions or you still need help. Please let me know.
I remember that I have come upon such issue in the past, reported it and it was fixed. I tried this with v13.1 of NetAdvantage and it works fine now. Could you please try to test your project against the latest service release of your latest version of NetAdvantage or against the trial version of 13.1 and let me know of the results.
