We have a line chart that has many points. The X-Axis labels across the bottom are not painting because there are too many values. I tried setting the Lables.Layout.Behavior to Auto and/or None, which didn't seem to help. Do you have a sample that shows how to draw the Axis labels at some defined interval, like paint every 10th value? It seems you had this question before, but the referenced links no longer work.
http://es.infragistics.com/community/forums/p/1764/14266.aspx#14266
Hello Ryork,
Here is a link to the page in our documentation that describes how to draw labels at a user-defined interval.
http://help.infragistics.com/NetAdvantage/WinForms/2013.1/CLR4.0/?page=Chart_Display_Labels_at_User_Defined_Interval.html
