I have an UltraCombo within a GridCell and this UltraCombo has a column (named selected) for row selection with the following property set
_savedSimResCombo.CheckedListSettings.CheckStateMember = "Selected";
I want the user to be able to use the groupBy feature but for some reason even though I set the groupByBoxHidden = false, the GroupByBox is invisible.
Is this a bug in UltraCombo or am I missing something.
I am using Infragistics V11.2
Sangeetha
Mike, Thank You for clarifying!
Georgi, It is a great idea. Thank you for your help!
This is the sample
This is the video file
Hi Sangeetha,
Maybe one possible approach to solve your task could be if you are using UserControl with desired functionality. I made small sample for you. Please take a look at the attached sample and video file for more details and let me know if you have any questions.
Regards
UltraCombo does not support grouping. The GroupByBox property shows up because the combo shares the same DisplayLayout object with the WinGrid, but it is not supported.
