740
Sort Ultragrid with Date Column
Hi there,
I have following fields displayed in a gird and sorted out by day, month and year ascending as stated below in the ORDER BY clause.
SELECT
title,first_name,surname,date_of_birth,age,street,suburb,state,postcode
FROM #temp_bday
ORDER BY DAY(date_of_birth) ASC, MONTH(date_of_birth) ASC, YEAR(date_of_birth) ASC
When the data loads it shows the sorting correctly in the grid. But my other requirement is, If the DOB header is selected (to sort the data manually by this field) use the same rule to sort the data. (Rule : ORDER BY DAY(date_of_birth) ASC, MONTH(date_of_birth) ASC, YEAR(date_of_birth) ASC)
I've tried to use the SortComparer for this, but i cant seems to find a way to sort the field by parts of the date.
Could I please get some help from anyone for this?? I have done string & integer compares with SortComparer but cant seem to think of a solution to sort datetime as parts of the date (eg. day, month and year)
If someone can provide a Sample code, that would be great!!! Need it ASAP!!
Thanks in Advance!!
PS: Sample for Datetime compare i did ( which is not working for the above rule)
//init gird//
ultragrid1.DisplayLayout.Bands[0].Columns["date_of_birth"].SortComparer = new dateComparer();
public class dateComparer : IComparer
public dateComparer()
public int Compare(object x, object y)
UltraGridCell xCell = (UltraGridCell)x;
UltraGridCell yCell = (UltraGridCell)y;
return DateTime.Compare(Convert.ToDateTime(xCell.Row.Cells["date_of_birth"].Value), Convert.ToDateTime(yCell.Row.Cells["date_of_birth"].Value));
