I tried the databinding capability of ganttview, and during our testing, we tried to add thousands of rows, and to our surprise, the next time we load the data, it displays an error "System.NullReferenceException: Object reference not set to an instance of an object at....., please see attached image.
Hello LSG,
I have logged a development issue for this.
You can view the status of the development issue connected to this case by selecting the "Development Issues" tab when viewing your active cases on the web site.
I am still investigating this issue. I reproduced the issue by creating a local database with tblProjectTasks and tblProjectMaster with only 1 task. The TaskCode had a value, so I am not sure what can and can't be null.
Please let me know if you have any questions or concerns.
Please see attached DB Script file.
Yes, I only received the SQL script and your updated project file. I see that you removed all the insert statements in the SQL query, has anything else been altered?
I sent the SQL script together the updated project file. Can you please verify. Thanks
