1105
Text right-to-left
Hi, I'm trying to export right-to-left string into PDF using your export component (Documents.Report). I'm adding a text field with text like 'abc 123' and the output appear as 'abc 321', while the abc part if in a right-to-left language (Hebrew). Is there a solution for this issue? does the PDF exporter supports rtl languages?
the code is very simple, something like band.AddText(), and text.AddContent(...)
