we have an application that is used to store patient information. we allow users to enter appointments for specific patients. when viewing we can view all appointments, or only appointments per specific patient. The issue we are seeing is as follows. When a reoccuring appointment is created without an end date, the appointment shows up under all patients after its "default" 3 month duration. to reproduce: setup a project that has 2 patients. add reminders for one patient. these should be the only ones visible in that patients view. Now for the second patient add a reoccuring appointment without an end date. navigate back to view only patient ones appointments. if you scroll into the future you begin to see the reoccuring appoint for patient 2 this should not be the case, only patient ones appointments should be visible.
Hello petetataliba,
I`m not sure that I udnerstand your scenario. Could you please give us more details, which control you are using into your application (UltraDayView, UltraMonthView, UltraTimelineView and so on) Also what is your current version and do you have any installed service release and which one. Are you able to upload small sample that reproduce your issue. I`ll be glad to research it for you.
Regards
we are using the ultramonthview. At this time i dont have the time to create a sample. the version is 12.2.20122.2061. basically we are trying to filter out appointments on a per patient basis and if it is a reoccuring reminder without an end date the filter does not work. if the recurrance dialog has a date 3 months out in it,but the end radio button is not checked, the reoccuring appoint begins showing for other patients after the end date.
Hello Pete,
I used one of our samples and I try to reproduce your issue following provided steps, but without success. Could you please take a look at the attached sample and if you think that I didn`t reproduce your scenario, please feel free to modify this sample to reproduce your issue and revert it back to me. I`ll be glad to research it for you.
Let me know if you have any questions.,
If you need any additional assistance with this case feel free to contact me.
