2549
CellAppearance problem with WinGrid when removing entry from datasource
Hi all,
I am currently facing a strange problem with the WinGrid.
It is a standard WinGrid, bound to an object datasource (List<item>).
I added an UnboundColumn to display a "light" icon that indicates its status (red, green).
On InitializeRow the calculation is done and a predefined (for reuse) Appearance is assigned to the cell (unbound column).
Now imagine the following rows (Id, IndicatorImage):
1     green
2     green
3     red
4     red
now if I remove the data entry from the datasource that contains Id = 2 I assumed to have the following rows:
1     green
3     red
4     red
Unfortunately I get this:
1     green
3     green
4     red
It seems that the indicator image stays the same for the rows (the bottom one is removed though)
Any hint is kindly appreciated,
best regards
Andy
