I have of grid which currently has Fixerd rows at the bottom. Is it possible to put a splitter at the top of the fixed rows to shrink or expand the fixed rows area. Or could RowScrollRegions do this. I don't want to see all rows in both regions - only the nonfixed in the upper region and fixed only in lower region.
Thakns,
Ron
Has the content been added?
I already have this. I need to be able to drag the row separator vertically to resize the FixedRows area. Is there any way to do this? RowScrollRegions? I'm trying to avoid having 2 grids.
Hi Ron,
You could use the 'SpecialRowSeparator' property on the 'Override' object of the grid's layout, setting it to 'FixedRows', like this:
private void ultraGrid1_InitializeLayout(object sender, Infragistics.Win.UltraWinGrid.InitializeLayoutEventArgs e)
e.Layout.Override.FixedRowStyle = Infragistics.Win.UltraWinGrid.FixedRowStyle.Bottom;
e.Layout.Override.SpecialRowSeparator = SpecialRowSeparator.FixedRows;
Does that meet your requirements?
