890
[Winform_UltraChart]databind a ultrachart to a SeriesCollection
Context : Ultrachart, style : line chart, winform, databinding
I am programming a window containing a Graph (LineChart) that can change depending of the user interaction.
I first code something using the series approach shown below :
http://es.infragistics.com/help/topic/EEB8F42A-9BEF-430E-8BAD-B99BB11B26E8
The result was Ok, but I was reinstantiating my ultrachart after each user interaction, that was not nice at all because of the flash due to reinstantiation.
So I plan to use databinding to modify my Series using SeriesCollection.
This time it was a big fail with the result (no error is thrown when executing) in the ultrachart I got the message :
Line Chart Error: You must have at least one row and one numeric column
I am doing my databinding this way :
private UltraChart _myUltraChart;
        private UltraChartBindingClass _myBindingClass;
        //constructor
        public ChartBuilder()
            //some method returning a linechart
            _myUltraChart = GetDefaultStyleUltraChart();
            _myBindingClass = new UltraChartBindingClass();
            //databinding
            //with Series : SeriesCollection Series
            _myUltraChart.DataSource = _myBindingClass.Series;
            _myUltraChart.Data.DataBind();
        //I got a method that feed my ultrachart :
        public void FeedMyUltraChart(IEnumerable myTimeSeries)
            foreach (var timeSerie in myTimeSeries)
                _myBindingClass.Series.Add(timeSerie);
                //I tried here to use _myUltraChart.Data.DataBind(); or _myUltraChart.Series.DataBind(); but nothing worked
        //I got a method to clean my series (can't clean anything now, because adding series doesn't work)
        public void CleanMySeries()
            _myBindingClass.Series.Clear();
What am I doing the wrong way to have my project working?
Regards
