1210
Adding a summary row programmatically
The following code works on a single row in the grid called Column 0. If I wanted to add another column to the summary such as Column 1, what do I need to do in the code below?
UltraGridBand band = ultraGrid1.DisplayLayout.Bands[0];
ultraGrid1.DisplayLayout.Bands[0].Columns["Column 0"].AllowRowSummaries = AllowRowSummaries.True;
 SummarySettings SumSummary = band.Summaries.Add("Sum " + "Column 0", SummaryType.Sum, band.Columns["Column 0"]);
SumSummary.DisplayFormat = "{0:#,##0.00}";
SumSummary.Appearance.TextHAlign = HAlign.Right;
 SumSummary.SummaryDisplayArea |= SummaryDisplayAreas.Bottom;
//ultraGrid1.DisplayLayout.Override.SummaryDisplayArea = SummaryDisplayAreas.Bottom;
 band.SummaryFooterCaption = "Subtotal:";
 band.Override.SummaryFooterCaptionAppearance.FontData.Bold = DefaultableBoolean.True;
band.Override.SummaryFooterCaptionAppearance.BackColor = Color.LightSteelBlue;
band.Override.SummaryFooterCaptionAppearance.ForeColor = Color.Black;
 // Here, I want to add grand total
UltraGridColumn columnToSummarize = band.Layout.Bands[0].Columns["Column 0"];
SummarySettings summary = band.Layout.Bands[0].Summaries.Add("Grand Total For " + "Column 0", SummaryType.Sum, columnToSummarize);
 summary.DisplayFormat = "{0:#,##0.00}";
summary.SummaryDisplayArea |= SummaryDisplayAreas.GroupByRowsFooter;
 summary.Appearance.TextHAlign = HAlign.Right;
// Disable grid default highlight
ultraGrid1.DisplayLayout.Override.ResetActiveRowAppearance();
ultraGrid1.DisplayLayout.Override.ResetActiveCellAppearance();
ultraGrid1.DisplayLayout.Override.ActiveAppearancesEnabled = DefaultableBoolean.False;
