3914
Bands not sorted in UltraGridColumnChooser
I have a multi band (hierarchical) Grid Data where say for example the bands are as follows Top Down:
Row1-Band0 : Band1, Band2, Band3
Row2-Band0 : Band4, Band5, Band6
Now, I sort the only Visible column in Band0, and Visually the bands display as follows:
Now Open the column chooser, you will notice that it displays Bands in the first mentioned order Band0, Band1, Band2, Band3, Band4, Band5, Band6
and not in the after column-sort-order Band0, Band4, Band5, Band6, Band1, Band2, Band3.
I added a print statement in AfterSortChangeEvent to check the Band VisiblePosition ... this was 0 - UNSET.
Although, Visually it seems to look like the bands have been sorted, the band VisualPosition/SortedIndex have not changed and hence UltraColumnChooser displays bands in the old order.
Is this a bug or designed that way. Is there a workaround without having to manually set the band's VisiblePosition.
Sangeetha
