4133
MaxLength Property Lost On Unbound Textbox
I have a textbox on my login form that is unbound.  I have set the MaxLength property to 20 characters in the designer.  However, whenever I run the app, the MaxLength property seems to get reset to zero.  I can tell this because I put a breakpoint in the Validating event and checked it.  This only seems to happen on unbound textboxes.  Bound textboxes seem to hold the property just fine.  If I set the property in code, it works fine.  Any idea why this would be happening?
  • 469350
    Verified Answer
    When you say TextBox, do you mean UltraTextEditor? If you are using an actual TextBox, I'm afraid that's a little but outside the scope of these forums. You would probably be better off and get more helpful responses on a Microsoft  or other generl DotNet WinForms forum. Smile
    Either way, I can't see any reason why the MaxLength would get reset. I tested this out in a simple form and set the UltraTextEditor MaxLength to 20, then checked in the Validating event and it works fine for me.
    Can you duplicate this in a small sample project?
    What version of the control are you using?
