Hi to all, after using UltraGrid from years one customer tell me that the ExcelExport functionality doesnt export the Summaries!!!
Going deep to know why the Summaries will no be exported I found that:
UltraGridExcelExporter export ONLY the Summaries of deeper Band in Layout!!!
My tests report that this happen with versions from 2009.2.20092 to 2012.2 Sr1.
Before that I open one support issue, anyone have had the same problem and have resolved it?
DavidePS: for Infrangistics Support: may be an internal flag that mark that summaries are exported? Because no Exporter event summaries-related was be called for other bands rather the depper.
I’ve opened a support thicket for you in our system. The id of the ticket is CAS-110801-S1Q4J6, so I will update you for the progress of my investigation trough the case.
Sorry ... one note on my test with your Project:
I've used .Net 4 Client profile and Infrtagistics CLR 4 2012.2 [12.2.20122.2027]
Thanks again for your time.
Davide.
another confirm about the link between NOT Exported Summaries and RowLayoutStyle.
In debug I changed the Band[0].RowLayoutStyle to NONE just before exporting and the SUMMARIES in Band 0 APPARED! ;)
Hi Hristo,thank you very much for your valuable time and project.
I saw that in your PRJ all woks fine.I tried to set the UG and the Summaries in the same manner in wich they are setted by our Framework ...
... and I found one set that "hide" the summaries in the XLS!
insert this line at line 54 of Form1.cs:band.RowLayoutStyle = RowLayoutStyle.ColumnLayout;and try it. in the Excel file the summaries are not exported.
I'll go ahead with my test settings the UG bands Layout similar that used in the real apps, meanwhile can you tell me about this issue with ColumnLayout? it's normal?
Thanks very much for you professional help.Davide.
I am just checking about the progress of this issue. Let me know If you need my further assistance on this issue?
