I upgraded to WinForms 12.1 and my application is receiving an innerexception error, and I can't seem to track down what it is. Below is my error stack. I was able to get an "Index out of range" message somewhere in the middle of all the exception messages, but not sure where or what index.
Any ideas would be helpful !!
System.InvalidOperationException was unhandled Message="An error occurred creating the form. See Exception.InnerException for details. The error is: The type initializer for 'InventoryManagement.Main' threw an exception." Source="InventoryManagement" StackTrace: at InventoryManagement.My.MyProject.MyForms.Create__Instance__[T](T Instance) in 17d14f5c-a337-4978-8281-53493378c1071.vb:line 190 at InventoryManagement.My.MyProject.MyForms.get_Main() at InventoryManagement.My.MyApplication.OnCreateMainForm() in C:\Dev\InventoryManagement\My Project\Application.Designer.vb:line 35 at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.OnRun() at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.DoApplicationModel() at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.Run(String[] commandLine) at InventoryManagement.My.MyApplication.Main(String[] Args) in 17d14f5c-a337-4978-8281-53493378c1071.vb:line 81 at System.AppDomain._nExecuteAssembly(Assembly assembly, String[] args) at System.AppDomain.ExecuteAssembly(String assemblyFile, Evidence assemblySecurity, String[] args) at Microsoft.VisualStudio.HostingProcess.HostProc.RunUsersAssembly() at System.Threading.ThreadHelper.ThreadStart_Context(Object state) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state) at System.Threading.ThreadHelper.ThreadStart()
I am just checking about the progress of this issue. Let me know If you need my further assistance on this issue?
I have reviewed your stack trace and nowhere I was able to find any Infragistics assembly that is referred there. You are saying that this exception occurs after you have been upgraded to Infragistics 12.1, so how exactly you have upgraded your solution, have you used Infragistics Version Utility or you have upgraded this manually. If you have upgraded manually have you clean the content of the license file from all Infragistics entries and have clean and rebuild your application ?
I am waiting for your response.
