Hi
I'm attaching a sample project where you can see this behavior and here is the brief (at least I hope so) description:
I have model with two properties e.g. FirstList and SecondList both of type BindingList<DataObject> and two properties FirstSelected and SecondSelected both of type List<object>.
On my form I have two UltraCombos with multiselection which DataSource properties are bound to FirstList and SecondList and whose Value properties are bound to FirstSelected and SecondSelected.
In my model I have some code that clears SecondList and fills it with respective elements if FirstSelected is changed.
The problem is when I first check some values in first combo then check some values in second combo and then uncheck values in first combo I expect the second combo to be cleared.
But instead I get the exception {"Value cannot be null.\r\nParameter name: key"} with stack trace:
at System.Collections.Generic.Dictionary`2.FindEntry(TKey key) at Infragistics.Win.UltraWinGrid.CheckedRowsCollection.VerifyCollection() at Infragistics.Win.UltraWinGrid.CheckedRowsCollection.Equals(List`1 values) at Infragistics.Win.UltraWinGrid.CheckedListSettings.OnRowsCollectionDataChanged(Object sender, DataChangedEventArgs e) at Infragistics.Win.UltraWinGrid.RowsCollection.FireDataChanged(DataChangedEventArgs args) at Infragistics.Win.UltraWinGrid.RowsCollection.OnListChanged(Object sender, ListChangedEventArgs e) at System.ComponentModel.ListChangedEventHandler.Invoke(Object sender, ListChangedEventArgs e) at System.Windows.Forms.BindingSource.OnListChanged(ListChangedEventArgs e) at System.Windows.Forms.BindingSource.ResetBindings(Boolean metadataChanged) at System.Windows.Forms.BindingSource.SetList(IList list, Boolean metaDataChanged, Boolean applySortAndFilter) at System.Windows.Forms.BindingSource.ParentCurrencyManager_CurrentItemChanged(Object sender, EventArgs e) at System.EventHandler.Invoke(Object sender, EventArgs e) at System.Windows.Forms.CurrencyManager.OnCurrentItemChanged(EventArgs e) at System.Windows.Forms.CurrencyManager.List_ListChanged(Object sender, ListChangedEventArgs e) at System.Windows.Forms.BindingSource.OnListChanged(ListChangedEventArgs e) at System.Windows.Forms.BindingSource.ListItem_PropertyChanged(Object sender, EventArgs e) at WindowsFormsApplication1.Model.OnSecondSelectedChanged() in C:\Users\chapand-a\documents\visual studio 2010\Projects\WindowsFormsApplication1\WindowsFormsApplication1\Model.cs:line 94 at WindowsFormsApplication1.Model.set_SecondSelected(List`1 value) in C:\Users\chapand-a\documents\visual studio 2010\Projects\WindowsFormsApplication1\WindowsFormsApplication1\Model.cs:line 84
Could something be done about it?
Please look at the attached solution for all details. Libraries versions are 10.2
Hi Michael, thank you very much, will wait for this issue to be solved
Andrey,
I have submitted this issue to our development team for further review. The reference number for the item is 132312. A support case has been opened for you with case number CAS-109634-H6F9Y5. You will receive more information on this item through the support case.
This appears to be a development issue which will I will submit to our development team. I will get back to you with a reference number as soon as I have done so.
Yes, I have reproduced the error with the sample you provided and we are investigating this now. I will get back to you with an update tomorrow.
Hi Michael, any news?
