250
ultragrid and a background worker
im using a background worker to fill a dataset from a sql query and setting the datasource of the ultragrid to that dataset. i sometimes get an object not set to an instance error while doing this and i think it must do with setting the grid datasource. i saw the help here : http://devcenter.infragistics.com/Support/KnowledgeBaseArticle.Aspx?ArticleID=9838
 but i am not using a collection as in the example. im not sure if i should be setting the datasource on the background thread or if i should fill the dataset on the background worker, and use the UI thread to bind the grid to the dataset. any help i would really appreciate. thanks
