375
maximum no of data rows that can be bound to a wingrid Infragistics11.1 version
I have search functionality in my winform application .Once the user clicks  search,respective data gets bound to the grid.Right now when i search for around 65000 records, it works fine. But when i try  to bind more than that, error comes up .  I use WCF to retrieve data from db. I get the following error ' The server did not provide a meaningful reply; this might be caused by a contract mismatch, a  premature session shutdown or an internal server error'(which i a wcf error) . In the grid i am binding more than 50 columns, i tried reducing the no of columns retrieved , then i was able to bind more than 85000 records. Is this a limitation in wingrid 11.1 version. Does further version of  infragistics provide with the flexiblity to bind large vloume of data...
  • 469350
    That error message appears to be coming from the back end or your data source. That's not a grid error.
    The WinGrid has no built-in row limit. There will, of course, be machine limitations based on available memory and system resources, but there should not be a problem with 85,000 rows. I've bound the ground to several hundred thousand rows, myself, with no problems.
    Having said that... no human user could possibly deal with such a large set of data in the UI, anyway. So perhaps you might want to consider displaying a message to the user that they need to refine their criteria to narrow the number of records returned by the search in a case where the search results are so large.
