80
How to concatenate two strings ?
I just starting looking at the Parsing Framework and I'd like to ask how to concatenate two strings without space?
for example: the concatenation of "snow" and "ball" is "snowball",  not "snow ball"
?TERMINAL_SYMBOL? KEY1= ?IGNORE_CASE? "snow";
?TERMINAL_SYMBOL? KEY2= ?IGNORE_CASE? "ball";
?START? word =KEY1,KEY2;
?START? word = ??????????????????????????
  • 44743
    If you have a unit of text you would like the parser to treat as a single unit without ignoring insignificant text withing it (such as whitespace), then you should define it as a terminal symbol. So let's say you need the terminal symbol "snow" in some cases, "ball" in other cases, and "snowball" in some other cases. Then you should define three terminal symbols: "snow", "ball", and "snowball". The lexical analysis phase will choose the longest piece of text possible which forms a valid token, so when faced with the text "snowball", it will not create a "snow" token followed by a "ball" token. It will just create a single "snowball" token.
