280
EmbeddableEditor display value caching
I am using an IEditorDataFilter to control how my data is displayed. The display of the data changes depending on whether the cell is active (i.e. in edit mode). This causes issues with the default behavior of UltraGrids sharing editors with other columns of the same style/among cells in the same column, as when the editor is in edit mode, it uses a cached result instead of getting the value from the IEditorDataFilter, even though the cached value is for a different cell.
For example, suppose I want the decimal 0 to be displayed as "0" when not in edit mode and as "0.0" when in edit mode, and both cell a and cell b have a value of 0. If cell a is in edit mode and I mouseover to cell b, then cell b will also display as "0.0" even though it is not in edit mode.
Currently, the only way to avoid this seems to be to set the editor of each cell to a separate object, which seems like a waste of memory. Is there a better way of accomplishing what I am trying to do?
