425
animated gif in tab
Is it possible to have an animated gif next to the tab caption for each tab?  I would like to show some kind of loading icon while the tab contents are loading.  If this is not standard, can you suggest how to do this with a custom draw filter.
Eric
  • 44743
    Verified Answer
    You can submit a feature request for this here: http://devcenter.infragistics.com/Protected/RequestFeature.aspx.
    As a workaround, you can use the following code:
    private void OnAnimateImage( object sender, EventArgs args )
     if ( this.ultraTabControl1.IsHandleCreated &&
      this.ultraTabControl1.InvokeRequired )
      this.ultraTabControl1.BeginInvoke( new EventHandler( this.OnAnimateImage ), (Image)sender );
     else
      foreach ( UltraTab tab in this.ultraTabControl1.Tabs )
       if ( tab.Appearance.Image != sender )
        continue;
       if ( this.ultraTabControl1.UIElement != null )
        UIElement element = this.ultraTabControl1.UIElement.GetDescendant( typeof( TabItemUIElement ), tab );
        if ( element != null )
         element.Invalidate();
       break;
    private void Form1_Load( object sender, EventArgs e )
     this.ultraTabControl1.Paint += new System.Windows.Forms.PaintEventHandler( this.ultraTabControl1_Paint );
     ImageAnimator.Animate( (Image)this.ultraTabControl1.Tabs[ 0 ].Appearance.Image, new EventHandler( this.OnAnimateImage ) );
    private void Form1_FormClosed( object sender, FormClosedEventArgs e )
     ImageAnimator.StopAnimate( (Image)this.ultraTabControl1.Tabs[ 0 ].Appearance.Image, new EventHandler( this.OnAnimateImage ) );
    private void ultraTabControl1_Paint( object sender, PaintEventArgs e )
     ImageAnimator.UpdateFrames();
