i created a chart text property to the ChartTextCollection of my BarChart.
Actually the Label is just above the bar. Is it possible to show the Label insight a Column in vertical adjustment ?
Many thanks for your example Application.
I found the cause of failure. I used Infragistics DLL's with the Version number 10.2
Now i am using 11.1 as in your example Application and it works without any code changes in my Application.
Strange stuff, i tried a lot of things and nothing was helpfully. But now with the newer DLL's it looks fine.
Thanks for your help !
this is the sample
Hello fpollmann,
I try to reproduce your scenario in a small sample, but without success. Could you please take a look at the attached sample and video file and let me know if you think that I didn`t reproduce your scenario and issue. Please modify this sample and revert it back to me. I`ll be glad to research it for you ad help you.
Regards
Hello Georgi,
i set the Y Axis ScrollScale as you wrote it (them of Axis X), but then the labels of the lower values are also not visible.
I attached a new Screenshot of the current state.
Isn't it possible to catch the value Labels (above the bar) in an event for example and change the location of the labels ?
Then i could change the location of the labels from the Bars with a higher value of 20 for example.
Thanks for your help by the way :-)
Thanks for attached screenshot. The mentioned behavior is expected due to your item GRKZ5060. Maybe one possible solution could be if you are using ScrollScale of your X axis. For example:
ultraChart1.Axis.X.ScrollScale.Visible = true;ultraChart1.Axis.X.ScrollScale.Scale = 0.2;
