270
Freezing Groups in WinGrid
I have successfully implemented column groups in my wingrid via the row layouts.  Now that I've done that, I need to freeze the first group (containing the first two data columns) so as I scroll horizontally that group stays put.
I've tried everything I can think of based on what I've found in your forum, but nothing seems to work.  Since I have three grouped headings, I had to create two groups for the first two columns.  One is the parent of the other. The groups are named GC_Empty and Empty and contain data columns 1 and 2 (column 0 is hidden).  So I assumed that I would do one of the following (or both)
1.         GC_Empty.Header.Fixed  = true;
2.      band.Columns[1].Header.Fixed = true;
         band.Columns[2].Header.Fixed = true;
Then afterwards: ugManagers.DisplayLayout.Override.FixedCellSeparatorColor = Color.Red;
Thanks in advance,
Paul
