185
Toolbar Hiding Window's TitleBar
I am facing problems with the UltraToolBarManager. I intend to place the toolbar in the titlebar of the Window. I set the DockWithinContainer property for the ToolBarManager as the host form & use the Top DockArea to place the toolbar. This places the toolbar right next to the host window icon. The problem I face is that when this Window becomes inactive inside my application the toolbar hides the hosted form icon on the left and the minimize, maximize & close button on the right. This happens when the Window is an MDI window. When I detach the window from the main application, it behaves perfectly. But when I attach it back the same issue remains. There are no issues when the window is either in SDI (active/inactive) or  MDI (active) modes. The problem appears only when being an MDI window, the window becomes inactive.
Kindly advise about how to solve this issue
Mayank
