125
Auto Resizing Row height as per the text size in cells
When a user clicks in between two rows, how can I autoresize the row height so that all data in each cell of the row is visible and not cut off?
For example in my snapshot below, when the user clicks in between the two rows, I want the text in column 2 (NEW YORK TEST CUSTOMER) to be displayed properly.
I have the following properties set:
grdTest.DisplayLayout.Override.RowSizing = RowSizing.Sychronized;
grdTest.DisplayLayout.Override.RowSizingArea = RowSizingArea.EntireRow;
grdTest.DisplayLayout.Override.MergedCellStyle = MergedCellStyle.OnlyWhenSorted;
Thanks!
- Zef
  • 20872
    Verified Answer
    Hello Zef,
    We are still following this forum thread. Have you been able to take a look at the provided code snippet?
    Please feel free to let us know if you have any questions or concerns about this matter.
  • 71886
    Verified Answer
    You could achieve this with the following code sample:
            private void ultraGrid1_InitializeLayout(object sender, Infragistics.Win.UltraWinGrid.InitializeLayoutEventArgs e)
                e.Layout.Override.CellMultiLine = Infragistics.Win.DefaultableBoolean.True;
                e.Layout.Override.RowSizing = Infragistics.Win.UltraWinGrid.RowSizing.AutoFree;
    You could play with the 'RowSizing' property, it is the essential one in this case.
