I would like to validated choice on combo box on UltraWinToolBars
I always set de procedure on ToolValueChaged, but I can have acces to e.cancell or oldvalue if not validated
If I use AfterToolExitMode was work but I can't find How I can force the exit on edit mode AfterToolCloseup.
Private Sub utm_AfterToolCloseup(sender As Object, e As Infragistics.Win.UltraWinToolbars.ToolDropdownEventArgs) Handles utm.AfterToolCloseup
e.Tool.ToolbarsManager
End Sub
Yes thank you.
Francois
Does that suggestion work for you?
François,
There is no PerformAction method off the ToolbarsManager. But don't you find that setting another Tool as "Active" has the same effect?
Yes I would like just exit on edit mode after selected one item on combo list.
You said,
e.Tool.ToolbarsManager.Toolbars(0).Tools(2).IsActiveTool = True is exit on edit mode ?
Usually it has a command like "PerformAction(ExitEditMode)" or .Editor.ExitEditMode(...)
Francois.
I don't really understand what you want to do. In the "AfterToolCloseup" event you could set another tool as active by doing something like this:
That would take the ComboBox out of edit mode. Is that what you want?
