We recently upgraded our app from .NET Framework 1.1 to 2.0 The conversion from Infrag 7.1 CLR 1 to CLR 2 went very smoothly but the application would hang with unresponsive windows after a user returned from the Screen being locked. While this is not necessarily an Infragistics problem I did come here looking for answers and found none so that's why I am posting. It turns out that certain controls register for the OnUserPreferenceChanged event which fires when you change your desktop background bitmap or unlock a screensaver.
I believe that some Infragistics controls also register for this event. The real problem is that in .NET Framework 2.0 the creation of handles for Windows is deferred (allegedly to improve performance). If you make the mistake I did and fire an asynchrounous thread to go and get some data to fill an Ultragrid before your UI window has a handle, InvokeRequired will lie to you. You will think you are on the main UI thread when you are still on the asynch thread. Then since you are not on a UI thread, messages are not received and the app hangs waiting forever.
A more elegant explanation from someone far brighter than I am:
http://ikriv.com:8765/en/prog/info/dotnet/MysteriousHang.html (Ivan refers to third party controls such as Infragistics and his sample of the bug with a Freezer app is especially useful in debugging- "E.g., Infragistics library creates a hidden form that it uses for device context measurements. Thus, you may be doing an innocent looking Infragistics call, but it will create a Windows Form and subscribe to the UserPreferenceChanged event. ")
and a solution at:
http://krgreenlee.blogspot.com/2007/09/onuserpreferencechanged-hang.html
Microsoft's knowledge base article was not much help.
http://support.microsoft.com/default.aspx?scid=kb;en-us;943139
I hope this saves someone else from three weeks of banging their head against the wall.
I'm getting the same kind of problem, where would you place this piece of code? after the initialize?
Many thanks in advance
bragancam
I had a similar problem don't know if anyone else has had this, bt I converted my vs2003 to vs2005 and we had netadvantage 2004 installed, then we would get desinger loading errors, that would go away if we just closed and opened the form a seoncd time, something to do with the resx that was not being properly updated by infragistic when we made changes in the grids. Then we decided to look at updating to a newer version of infragistic, and all their little stupid utility did was update the vbproj reference to the dlls (something i can do manually in seconds)....now we have even more problems compiling then before and has everything to do with the grids ....Anyone can offer help or advice with this problem as it sounds alot to do with this topic???
I followed Kim Greenlee's idea of insuring that every control has a handle
List lstHandles = new List();IntPtr hTemp;foreach (Control myCtrl in Controls){ hTemp = myCtrl.Handle; lstHandles.Add(hTemp);}hTemp = Handle;lstHandles.Add(hTemp);lstHandles.Clear();
AND moved my Asynch database query out of the Form Load
This is exactly the problem I have. Thanks alot for your post.
Which solution did you use?
