What I would like to do is to reorder the flyout tabs that are shown each the 'AfterPaneButtonClick' event is raised. Flyout tabs on the top would sort with other flyout tabs on the top, left with left, and so on. The idea is to impose an order on the flyout tabs.
Do you have any example code that shows how to do this?
Patrick
Hello Pat,
Thanks for your response and sample. Please feel free to write us if you have any questions.
Regards
Here's a better version of what I sent before.
I can't detect any flashing in the test casse.
I think this is closed.
Pat
I am sure that the flashing is due tot he unpin/pin loops. I would have expected, though, that suspending the layout would have suppressed this behavior.
Ah, implement the 'IDockingArea.PriorityLevel' - I can make a stab-in-the-dark on this, I guess. Do you have any examples you can refer me to?
It would have been nice if the collection of tabs could have been resorted...
Hello Mchargue,
Thanks for attached sample. Looking at the sample`s code, I think that flickering is due to your loops to Pin and Unpin the panes. I comment this piece of code and I think that everything works properly. I suppose that you are using these loops to determinate the priority of your panes. If I`m right about my guess, maybe you could try to implement IDockingArea.PriorityLevel interface instead of tese two loops.
The only problem I am having with the demo that I posted is that there is a lot of flashing going on when I do the re-sort. This, even though I suspend the layout of the form containing the UltraDockManager control, and suspend the layout of the UltraDockManager control itself. Is there a better way to accomplish this sort that doesn't pin/unpin DockAreaPanes, or a way to minimize the flashing that occurs?
