1310
Dynamically make change in the ultratoolbarmanager
Hello
I have a label tool and a button tool in the ribbon.
When the form loads, The label text need to be the current date. On click of the button, a window appears in which we are able to select a date, and click the Ok button.
Then the selected date should display in the label which previously had the current date in the ribbon.
Kindly reply with a solution.
Regards
jeni
  • 1310
    This issue is resolved. Simply changing the Caption helped.
    this.ultraToolbarsManager1.Tools["Toolkey"].SharedProps.Caption
