I am using ultradocManager control for creating docable panels. The docable panels showing right side from the starting point of the form and not showing below end borders. The below end borders are opened. how to make below end border as closed.
Hello vinod,
Maybe you could try to set these two properties to acheive desired look and feel:
dgpGroup.DefaultPaneSettings.BorderStylePane = Infragistics.Win.UIElementBorderStyle.Raised;// RaisedSoft;// Rounded4Thick;// Default;
ultraDockManager1.WindowStyle = WindowStyle.VisualStudio2008;// Office2003;// Default;
Please take a look at the attached video file for more details and let me know if you have any questions.
Regards
The using code is below.
DockableControlPane dcpAppView; DockableControlPane dcpDocsView; DockableGroupPane dgpGroup; DockAreaPane dapControls;
SuspendLayout();
UsrCntrlApplicationPanel usrApps = new UsrCntrlApplicationPanel(); dcpAppView = new DockableControlPane("apps", "Applications", usrApps);
UsrCntrlDocumentPanel usrDocs = new UsrCntrlDocumentPanel(); dcpDocsView = new DockableControlPane("Documents", "Documents", usrDocs);
dgpGroup = new DockableGroupPane(); dgpGroup.ChildPaneStyle = ChildPaneStyle.VerticalSplit; dgpGroup.Panes.Add(dcpAppView); dgpGroup.Panes.Add(dcpDocsView); dgpGroup.ChildPaneStyle = ChildPaneStyle.HorizontalSplit;
dapControls = new DockAreaPane(DockedLocation.DockedRight);
dapControls.Size = new System.Drawing.Size(200, 200);
dapControls.Panes.Add(dgpGroup);
dcpDocsView.Unpin(); dcpDocsView.FlyoutSize = new Size(200, 200);
//this.DockManager.DockAreas.Clear(); this.ultraDockManagerDocPanels.DockAreas.Add(dapControls);
ResumeLayout();
Here is the sample
Hello Vinod,
I`m not sure that I understand well your issue. Could you please take a look at the attached sample and let me know if you think that I didn`t reproduce your issue. Please feel free to modify this sample to reproduce your scenario and revert it back to me. I`ll be glad to research this issue for you. Please provide more details about this issue. Also could you please tell us what is your current version and do you have any installed service release and which one.
