I am facing a problem after upgrading my infragistics from 7.3 to 12.1.
I have binded a binding list with the UltraGrid.
Sometimes when calling bindinglist.Remove() method grid goes to hang state permanently.
My Generic function code is:
public void Remove(T item) { try { if (_dict.ContainsKey(item.GetKey())) { T olditem = GetItem(item.GetKey()); base.Remove(olditem); _dict.Remove(item.GetKey()); } } catch (Exception ex) { // Invoke our policy that is responsible for making sure no secure information // gets out of our layer. bool rethrow = ExceptionPolicy.HandleException(ex, Global.ApplicationConstants.POLICY_LOGANDSHOW);
if (rethrow) { throw; } } }
I need urgent help;
Plzzzzzzzzzzzz.
Thanks in advance.
I have found an temporary workaround for this issue.
When we set base.RaiseListChangedEvents = true; or call base.ResetBindings() before removing item from the list then wingrid never hangs.
I want solution for the following topics:
1. Is there any adverse effect on performance of using base.RaiseListChangedEvents/base.ResetBindings() ?
2. Same binding list is used in many controls, why we get ui hangs in specific control after upgrading infragistics.?
My changed generic method code is:
public void Remove(T item){try{if (_dict.ContainsKey(item.GetKey())){T olditem = GetItem(item.GetKey());
// base.ResetBindings();base.Remove(olditem);_dict.Remove(item.GetKey());}}catch (Exception ex){// Invoke our policy that is responsible for making sure no secure information// gets out of our layer.bool rethrow = ExceptionPolicy.HandleException(ex, Global.ApplicationConstants.POLICY_LOGANDSHOW);
if (rethrow){throw;}}}
I cant make a sample project because hanging scenario is produced when using binding list with an specific module of our application but it was not producible in infragistics 7.1.
I am checking about the progress of this issue. Please let me know If you need any further assistance on this.
Could you please try to attach if possible a small sample project reproducing the above mentioned issue, I will be happy to take a look at it.
