665
Ribbon Caption not correctly displaying text in MDI format
I may have found bug, but not sure.  Please check this out.
I have a MDI Parent form with the [Text] property set to: <Something>.
I also have two test Forms called [Form1] and [Form2], and their
respective [Text] property values set accordingly <Form1> and <Form2>.
On the MDI form I have your UltraToolbarsManager.  With [MDIMergeable] set to <True>
Both of the other forms also have  your UltraToolbarsManager.  All forms
have several tabs with controls in the ribbons (for test purposes).
Now when I first ran this project the Parent form had the correct text in Top
section of the ribbon area, and when you launched the other forms their text was
also displayed. (with the child form maximized within the parent form)
Exp:  OptiSave - [Board Comparison]
But, after playing with the ribbon [caption] property on all the UltraToolbarsManager tools
on each form that text is NO longer displayed as before.
I've tried creating several other small projects and same result after changing the ribbon
caption value.  If don't mess with it, all is well.
I would like to be able to get my main project to display whatever text I have for the
parent form, followed by the currently displayed and focused form, so the user can quickly
determine where they have navigated. Similar to any other Windows program out there.
What am I doing wrong, or right??
Help!!
 Thanks ahead of time,
PR
  • 44743
    Verified Answer
    This is correct behavior. Setting the UltraToolbarsManager.Ribbon.Caption property to a value will prevent the normal caption of "<MdiParentText> - [<MdiChildText>] to appear and mdi child are activated. To get back to the default behavior, set the UltraToolbarsManager.Ribbon.Caption back to null.
