765
Data Error: Unable to update the data value: column
 So I have an UltraWinTree that only allows editing of the check boxes. When I check a box it seems to be ok but when I go to select another node after checking a box I get a message box that pops up that says:
I'm not even sure where to begin with this error.  I have no idea what is causing it.  I can usually go from node to node and select different nodes but as soon as I check a box and select a different node it makes this box appear.  Its hard to debug an error when I don't know where its breaking.
