965
Summary Column Value based on custom business logic
I am adding a summary row to about 20 Grids in our application.
Some of the columns only need to be summed or show a max value so I have used the following code to do this.
grid1.DisplayLayout.Bands[0].Summaries.Add("Column1", SummaryType.Sum, grid1.DisplayLayout.Bands[0].Columns["Column1"]);
grid1.DisplayLayout.Bands[0].Summaries["Column1"].DisplayFormat = "{0}";
grid1.DisplayLayout.Bands[0].Summaries.Add("Column2", SummaryType.Maximum, grid1.DisplayLayout.Bands[0].Columns["Column2"]);
grid1.DisplayLayout.Bands[0].Summaries["Column2"].DisplayFormat = "{0}";
Other columns need to be calculated based on custom business logic.
For example the value in Column5 is determined by ... if Column2 > 25 we multiple Column1 by Column3, if Column2 < 25 we divide Column1 by Column4.
This is an example and some of the calculations are more complicated than this so I don't believe using UltraCalcManager Formulas is not the answer.
I'd like to create a function that calculates the Value based on other summary values. I looked at the ExternalSummary functionality but am not sure how to populate the values based on a function?
