I can add an ultraDataSource to the form directly but then it does not have the Import Schema From DataSource button
Hi stokara,
If you have any further questions regarding this behavior, please let me know.
Sincerely,Chris KDeveloper Support EngineerInfragistics, Inc.www.infragistics.com/support
The “Import Schema From DataSource” button will remain available if an UltraDataSource is being implemented as well as when it is not.
This button is accessed within the UltraGrid’s designer, under Basic Settings > Data Schema. Next, you will need to activate the “Manually Define a Schema” button, along the bottom of the proceeding window you will find the “Import Schema From DataSource” button.
If you have any further questions or if I have misunderstood your inquiry, please let me know.
