Hi everyone!!
I have a Wingrid on my APP and I need to get the Appearance of Header Row (backcolor and font).
Is there any property that I can use for this?
Thank you.
Beste regards,
Maria
First of all I want to thank you for your quick reply!
What I said "Header row" I meant the first "row" of the grid, where the Columns names appear.
I've already tried to use CaptionAppearance but in my particular case it doesn't help.
However, I found a way to solve my problem without using the grid's properties. :)
Best regards,
Actually, the CaptionAppearance will not be very helpful, because it will only return properties that you set on it. It doesn't return the actual on-screen appearance. You will probably need to call a method to resolve the appearance, but it's not clear what you mean by "Header Row". So if you could clarify what you are referring to, I could probably point you to the right method and give you some sample code.
Hello Maria,
If you mean the 'Caption' of the WinGrid control, at least this is what I understood from your post, you could access its appearance through:
ultraGrid1.DisplayLayout.CaptionAppearance
Please feel free to let me know if I misunderstood you or if you have any other questions.
