1104
Selection after double-clicking a DateTime cell
when using style "DateTime" or similar styles for columns, the following behaviour would be very useful:
When the user activates the cell and then doubleclicks e.g. on the 2-digit hour value, these 2 digits should be selected.
However, by default the whole cell value is selected.
What would be the easiest way to change this?
Thank you,
best regards
  • 48586
    Verified Answer
    Hello ,
    the easiest way to achieve functionality that allows you to select a section from the default date time, is to handle ClickCell event of UltrtaGrid and to put there following code lines:
    if (e.Cell.EditorResolved is Infragistics.Win.DateTimeEditor)
                ((Infragistics.Win.DateTimeEditor)(e.Cell.EditorResolved)).PerformAction(Infragistics.Win.UltraWinMaskedEdit.MaskedEditAction.SelectSection, false, false);
    Please see attached sample. So on first click user will select a specific section and on the double click will select whole cell value.
    99919.zip
