For grids with several levels of data the first column is padded so the other columns are aligned, my question is if it would be possible to increase the padding of each level depending of the bands that are expanded.
Yes, we had to get to an intermediate solution to avoid hitting the performance.
Hello jcmarq,
I wanted to know if you were able to solve your issue based on these suggestions or you still need help. Please let me know.
Ah, I see. No, there's no automatic way to do this. The main reason we don't do it automatically is one of performance. Doing this would require determining the expanded state of all of the rows on a particular level. For the root level rows, this is not so bad, but for each level you go down, it increases exponentially.
If you know you have a relatively small set of data, it should be possible for you to code it, I think.
What I want to achieve is that if we have bands for the level "i+" collapsed those bands and their child will have Indentaion = 0 until expanded.
I'm coding this my self with the OnAfterCollapsed/OnBeforeExpand events, but will be good to know if there is some way of doing that in an automatic/standard way.
I'm not sure what you mean by "depending of the bands that are expanded." You can control the indentation on each band using the Indentation property on the band.
