Hi ,
I am using calender control on my form , and i am displaying the date .
when i select the control it is throwing exception "
Can't call DropDown unless the Editor is in edit mode"
How do I fix this issue for the calender control.
Ishnant
This call stack doesn't even reference any "calendar control". This shows an exception when clicking on a grid cell.
Anyway, I'm pretty sure this is a know bug that was fixed a long time ago. You probably just need the latest service release.
See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************System.InvalidOperationException: Can't call DropDown unless the Editor is in edit mode. at Infragistics.Win.EditorWithText.get_CurrentEditText() at Infragistics.Win.UltraWinGrid.UltraGridCell.CommitEditValue(Boolean& stayInEdit, Boolean fireDataError, Boolean forceDontThrowException, Boolean dontStoreInUndoHistory) at Infragistics.Win.UltraWinGrid.UltraGridCell.CommitEditValue(Boolean& stayInEdit, Boolean fireDataError, Boolean forceDontThrowException) at Infragistics.Win.UltraWinGrid.UltraGridLayout.OnEditorBeforeExitEditMode(Object sender, BeforeExitEditModeEventArgs e) at Infragistics.Win.EmbeddableEditorBase.OnBeforeExitEditMode(Boolean& cancel, Boolean forceExit, Boolean applyChanges) at Infragistics.Win.EditorWithText.OnBeforeExitEditMode(Boolean& cancel, Boolean forceExit, Boolean applyChanges) at Infragistics.Win.EmbeddableEditorBase.ExitEditMode(Boolean forceExit, Boolean applyChanges) at Infragistics.Win.UltraWinGrid.UltraGridCell.ExitEditMode(Boolean cancellingEditOperation, Boolean forceExit) at Infragistics.Win.UltraWinGrid.UltraGridCell.ExitEditMode() at Infragistics.Win.UltraWinGrid.UltraGridCell.Activate() at Infragistics.Win.UltraWinGrid.UltraGridCell.SetFocusAndActivate(Boolean byMouse, Boolean enterEditMode, Boolean byTabKey) at Infragistics.Win.UltraWinGrid.UltraGridCell.SetFocusAndActivate(Boolean byMouse, Boolean enterEditMode) at Infragistics.Win.UltraWinGrid.CellUIElementBase.OnEmbeddableElementMouseDown(Object sender, EmbeddableMouseDownEventArgs e) at Infragistics.Win.UltraWinGrid.GridEmbeddableEditorOwnerInfoBase.OnEditorMouseDown(EmbeddableUIElementBase embeddableElem, EmbeddableMouseDownEventArgs e) at Infragistics.Win.EmbeddableUIElementBase.RaiseMouseDownEvent(EmbeddableMouseDownEventArgs e) at Infragistics.Win.EmbeddableUIElementBase.OnMouseDown(EmbeddableMouseDownEventArgs e, Boolean adjustableArea, UIElement& captureMouseForElement) at Infragistics.Win.EditorWithTextUIElement.OnMouseDown(MouseEventArgs e, Boolean adjustableArea, UIElement& captureMouseForElement) at Infragistics.Win.UIElement.OnMouseDown(MouseEventArgs e, Boolean adjustableArea, UIElement& captureMouseForElement) at Infragistics.Win.TextUIElementBase.OnMouseDown(MouseEventArgs e, Boolean adjustableArea, UIElement& captureMouseForElement) at Infragistics.Win.EditorWithTextDisplayTextUIElement.OnMouseDown(MouseEventArgs e, Boolean adjustableArea, UIElement& captureMouseForElement) at Infragistics.Win.ControlUIElementBase.ProcessMouseDownHelper(Object sender, MouseEventArgs e) at Infragistics.Win.ControlUIElementBase.ProcessMouseDown(Object sender, MouseEventArgs e) at Infragistics.Win.Utilities.ProcessEvent(Control control, ProcessEvent eventToProcess, EventArgs e) at Infragistics.Win.UltraControlBase.OnMouseDown(MouseEventArgs e) at System.Windows.Forms.Control.WmMouseDown(Message& m, MouseButtons button, Int32 clicks) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************mscorlib Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.4961 (win7RTMGDR.050727-4900) CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll----------------------------------------Microsoft.VisualStudio.HostingProcess.Utilities Assembly Version: 10.0.0.0 Win32 Version: 10.0.30319.1 CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.VisualStudio.HostingProcess.Utilities/10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualStudio.HostingProcess.Utilities.dll----------------------------------------System.Windows.Forms Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.4961 (win7RTMGDR.050727-4900) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll----------------------------------------System Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.4962 (win7RTMGDR.050727-4900) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll----------------------------------------System.Drawing Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll----------------------------------------Microsoft.VisualStudio.HostingProcess.Utilities.Sync Assembly Version: 10.0.0.0 Win32 Version: 10.0.30319.1 CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.VisualStudio.HostingProcess.Utilities.Sync/10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualStudio.HostingProcess.Utilities.Sync.dll----------------------------------------Microsoft.VisualStudio.Debugger.Runtime Assembly Version: 10.0.0.0 Win32 Version: 10.0.30319.1 CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.VisualStudio.Debugger.Runtime/10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualStudio.Debugger.Runtime.dll----------------------------------------vshost32-clr2 Assembly Version: 10.0.0.0 Win32 Version: 10.0.30319.1 CodeBase: file:///D:/AFS%20OMS/RELEASE/AFSERPWIN/WinUI/bin/Debug/AFS.ERP.WinUI.vshost.exe----------------------------------------Microsoft.Web.Services3 Assembly Version: 3.0.0.0 Win32 Version: 3.0.5305.0 CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.Web.Services3/3.0.0.0__31bf3856ad364e35/Microsoft.Web.Services3.dll----------------------------------------PresentationCore Assembly Version: 3.0.0.0 Win32 Version: 3.0.6920.5001 built by: Win7RTMGDR CodeBase: file:///C:/Windows/assembly/GAC_32/PresentationCore/3.0.0.0__31bf3856ad364e35/PresentationCore.dll----------------------------------------WindowsBase Assembly Version: 3.0.0.0 Win32 Version: 3.0.6920.5001 built by: Win7RTMGDR CodeBase: file:///C:/Windows/assembly/GAC_MSIL/WindowsBase/3.0.0.0__31bf3856ad364e35/WindowsBase.dll----------------------------------------PresentationFramework Assembly Version: 3.0.0.0 Win32 Version: 3.0.6920.5001 built by: Win7RTMGDR CodeBase: file:///C:/Windows/assembly/GAC_MSIL/PresentationFramework/3.0.0.0__31bf3856ad364e35/PresentationFramework.dll----------------------------------------System.Configuration Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll----------------------------------------AFS.ERP.WinUI Assembly Version: 4.1.2127.2242 Win32 Version: 4.1.2127.2242 CodeBase: file:///D:/AFS%20OMS/RELEASE/AFSERPWIN/WinUI/bin/Debug/AFS.ERP.WinUI.EXE----------------------------------------System.Xml Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll----------------------------------------AFS.ERP.SystemFramework.UserControls Assembly Version: 4.1.577.577 Win32 Version: 4.1.577.577 CodeBase: file:///D:/AFS%20OMS/RELEASE/AFSERPWIN/WinUI/bin/Debug/AFS.ERP.SystemFramework.UserControls.DLL----------------------------------------Infragistics2.Win.v9.2 Assembly Version: 9.2.20092.1003 Win32 Version: 9.2.20092.1003 CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Infragistics2.Win.v9.2/9.2.20092.1003__7dd5c3163f2cd0cb/Infragistics2.Win.v9.2.dll----------------------------------------Infragistics2.Win.UltraWinStatusBar.v9.2 Assembly Version: 9.2.20092.1003 Win32 Version: 9.2.20092.1003 CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Infragistics2.Win.UltraWinStatusBar.v9.2/9.2.20092.1003__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinStatusBar.v9.2.dll----------------------------------------Infragistics2.Shared.v9.2 Assembly Version: 9.2.20092.1003 Win32 Version: 9.2.20092.1003 CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Infragistics2.Shared.v9.2/9.2.20092.1003__7dd5c3163f2cd0cb/Infragistics2.Shared.v9.2.dll----------------------------------------Infragistics2.Win.Misc.v9.2 Assembly Version: 9.2.20092.1003 Win32 Version: 9.2.20092.1003 CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Infragistics2.Win.Misc.v9.2/9.2.20092.1003__7dd5c3163f2cd0cb/Infragistics2.Win.Misc.v9.2.dll----------------------------------------Infragistics2.Win.UltraWinEditors.v9.2 Assembly Version: 9.2.20092.1003 Win32 Version: 9.2.20092.1003 CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Infragistics2.Win.UltraWinEditors.v9.2/9.2.20092.1003__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinEditors.v9.2.dll----------------------------------------AFS.ERP.Common.Utility Assembly Version: 4.1.299.299 Win32 Version: 4.1.299.299 CodeBase: file:///D:/AFS%20OMS/RELEASE/AFSERPWIN/WinUI/bin/Debug/AFS.ERP.Common.Utility.DLL----------------------------------------System.Data Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900) CodeBase: file:///C:/Windows/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll----------------------------------------AFS.ERP.Common.Resource Assembly Version: 4.1.202.202 Win32 Version: 4.1.202.202 CodeBase: file:///D:/AFS%20OMS/RELEASE/AFSERPWIN/WinUI/bin/Debug/AFS.ERP.Common.Resource.DLL----------------------------------------AFS.ERP.Common.Resource.resources Assembly Version: 4.1.202.202 Win32 Version: 4.1.202.202 CodeBase: file:///D:/AFS%20OMS/RELEASE/AFSERPWIN/WinUI/bin/Debug/en-US/AFS.ERP.Common.Resource.resources.DLL----------------------------------------log4net Assembly Version: 1.2.0.30714 Win32 Version: 1.2.0.30714 CodeBase: file:///D:/AFS%20OMS/RELEASE/AFSERPWIN/WinUI/bin/Debug/log4net.DLL----------------------------------------System.Web.Services Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Web.Services/2.0.0.0__b03f5f7f11d50a3a/System.Web.Services.dll----------------------------------------System.Runtime.Serialization Assembly Version: 3.0.0.0 Win32 Version: 3.0.4506.4926 (NetFXw7.030729-4900) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Runtime.Serialization/3.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll----------------------------------------System.Transactions Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900) CodeBase: file:///C:/Windows/assembly/GAC_32/System.Transactions/2.0.0.0__b77a5c561934e089/System.Transactions.dll----------------------------------------System.EnterpriseServices Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900) CodeBase: file:///C:/Windows/assembly/GAC_32/System.EnterpriseServices/2.0.0.0__b03f5f7f11d50a3a/System.EnterpriseServices.dll----------------------------------------Accessibility Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll----------------------------------------System.ServiceModel Assembly Version: 3.0.0.0 Win32 Version: 3.0.4506.4926 (NetFXw7.030729-4900) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.ServiceModel/3.0.0.0__b77a5c561934e089/System.ServiceModel.dll----------------------------------------SMDiagnostics Assembly Version: 3.0.0.0 Win32 Version: 3.0.4506.4926 (NetFXw7.030729-4900) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/SMDiagnostics/3.0.0.0__b77a5c561934e089/SMDiagnostics.dll----------------------------------------System.Web Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.4955 (win7RTMGDR.050727-4900) CodeBase: file:///C:/Windows/assembly/GAC_32/System.Web/2.0.0.0__b03f5f7f11d50a3a/System.Web.dll----------------------------------------System.WorkflowServices Assembly Version: 3.5.0.0 Win32 Version: 3.5.594.4926 CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.WorkflowServices/3.5.0.0__31bf3856ad364e35/System.WorkflowServices.dll----------------------------------------System.ServiceModel.Web Assembly Version: 3.5.0.0 Win32 Version: 3.5.594.4926 CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.ServiceModel.Web/3.5.0.0__31bf3856ad364e35/System.ServiceModel.Web.dll----------------------------------------Microsoft.VisualStudio.Diagnostics.ServiceModelSink Assembly Version: 3.0.0.0 Win32 Version: 10.0.30319.1 CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.VisualStudio.Diagnostics.ServiceModelSink/3.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualStudio.Diagnostics.ServiceModelSink.dll----------------------------------------System.IdentityModel Assembly Version: 3.0.0.0 Win32 Version: 3.0.4506.4926 (NetFXw7.030729-4900) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.IdentityModel/3.0.0.0__b77a5c561934e089/System.IdentityModel.dll----------------------------------------Infragistics2.Win.UltraWinExplorerBar.v9.2 Assembly Version: 9.2.20092.1003 Win32 Version: 9.2.20092.1003 CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Infragistics2.Win.UltraWinExplorerBar.v9.2/9.2.20092.1003__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinExplorerBar.v9.2.dll----------------------------------------Infragistics2.Win.UltraWinTree.v9.2 Assembly Version: 9.2.20092.1003 Win32 Version: 9.2.20092.1003 CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Infragistics2.Win.UltraWinTree.v9.2/9.2.20092.1003__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinTree.v9.2.dll----------------------------------------Infragistics2.Win.UltraWinDock.v9.2 Assembly Version: 9.2.20092.1003 Win32 Version: 9.2.20092.1003 CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Infragistics2.Win.UltraWinDock.v9.2/9.2.20092.1003__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinDock.v9.2.dll----------------------------------------Infragistics2.Win.UltraWinToolbars.v9.2 Assembly Version: 9.2.20092.1003 Win32 Version: 9.2.20092.1003 CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Infragistics2.Win.UltraWinToolbars.v9.2/9.2.20092.1003__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinToolbars.v9.2.dll----------------------------------------Infragistics2.Win.AppStylistSupport.v9.2 Assembly Version: 9.2.20092.1003 Win32 Version: 9.2.20092.1003 CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Infragistics2.Win.AppStylistSupport.v9.2/9.2.20092.1003__7dd5c3163f2cd0cb/Infragistics2.Win.AppStylistSupport.v9.2.dll----------------------------------------Infragistics2.Win.UltraWinTabbedMdi.v9.2 Assembly Version: 9.2.20092.1003 Win32 Version: 9.2.20092.1003 CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Infragistics2.Win.UltraWinTabbedMdi.v9.2/9.2.20092.1003__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinTabbedMdi.v9.2.dll----------------------------------------Infragistics.License Assembly Version: 1.0.5005.10 Win32 Version: 1.0.5005.10 CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Infragistics.License/1.0.5005.10__7dd5c3163f2cd0cb/Infragistics.License.dll----------------------------------------AFS.ERP.Common.CacheManagerUtility Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///D:/AFS%20OMS/RELEASE/AFSERPWIN/WinUI/bin/Debug/AFS.ERP.Common.CacheManagerUtility.DLL----------------------------------------Infragistics2.Win.UltraWinTabControl.v9.2 Assembly Version: 9.2.20092.1003 Win32 Version: 9.2.20092.1003 CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Infragistics2.Win.UltraWinTabControl.v9.2/9.2.20092.1003__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinTabControl.v9.2.dll----------------------------------------Infragistics2.Win.UltraWinGrid.v9.2 Assembly Version: 9.2.20092.1003 Win32 Version: 9.2.20092.1003 CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Infragistics2.Win.UltraWinGrid.v9.2/9.2.20092.1003__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinGrid.v9.2.dll----------------------------------------Infragistics2.Win.UltraWinGrid.ExcelExport.v9.2 Assembly Version: 9.2.20092.1003 Win32 Version: 9.2.20092.1003 CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Infragistics2.Win.UltraWinGrid.ExcelExport.v9.2/9.2.20092.1003__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinGrid.ExcelExport.v9.2.dll----------------------------------------Infragistics2.Excel.v9.2 Assembly Version: 9.2.20092.1003 Win32 Version: 9.2.20092.1003 CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Infragistics2.Excel.v9.2/9.2.20092.1003__7dd5c3163f2cd0cb/Infragistics2.Excel.v9.2.dll----------------------------------------System.Design Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Design/2.0.0.0__b03f5f7f11d50a3a/System.Design.dll----------------------------------------AFS.ERP.OrderEntry.WinUI Assembly Version: 0.0.0.0 Win32 Version: 0.0.0.0 CodeBase: file:///D:/AFS%20OMS/RELEASE/AFSERPWIN/WinUI/bin/Debug/AFS.ERP.OrderEntry.WinUI.DLL----------------------------------------Microsoft.Practices.EnterpriseLibrary.Caching Assembly Version: 2.0.0.0 Win32 Version: 2.0.0.0 CodeBase: file:///D:/AFS%20OMS/RELEASE/AFSERPWIN/WinUI/bin/Debug/Microsoft.Practices.EnterpriseLibrary.Caching.DLL----------------------------------------Microsoft.Practices.EnterpriseLibrary.Common Assembly Version: 2.0.0.0 Win32 Version: 2.0.0.0 CodeBase: file:///D:/AFS%20OMS/RELEASE/AFSERPWIN/WinUI/bin/Debug/Microsoft.Practices.EnterpriseLibrary.Common.DLL----------------------------------------Microsoft.Practices.ObjectBuilder Assembly Version: 1.0.51205.0 Win32 Version: 1.0.51205.0 CodeBase: file:///D:/AFS%20OMS/RELEASE/AFSERPWIN/WinUI/bin/Debug/Microsoft.Practices.ObjectBuilder.DLL----------------------------------------AFS.ERP.SystemFramework.UserControls.GridPropertiesSettings Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///D:/AFS%20OMS/RELEASE/AFSERPWIN/WinUI/bin/Debug/AFS.ERP.SystemFramework.UserControls.GridPropertiesSettings.DLL----------------------------------------System.Runtime.Serialization.Formatters.Soap Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Runtime.Serialization.Formatters.Soap/2.0.0.0__b03f5f7f11d50a3a/System.Runtime.Serialization.Formatters.Soap.dll----------------------------------------System.Security Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.4951 (win7RTMGDR.050727-4900) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Security/2.0.0.0__b03f5f7f11d50a3a/System.Security.dll----------------------------------------System.Configuration.Install Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration.Install/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.Install.dll----------------------------------------UIAutomationProvider Assembly Version: 3.0.0.0 Win32 Version: 3.0.6920.4902 built by: NetFXw7 CodeBase: file:///C:/Windows/assembly/GAC_MSIL/UIAutomationProvider/3.0.0.0__31bf3856ad364e35/UIAutomationProvider.dll----------------------------------------System.Data.SqlXml Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Data.SqlXml/2.0.0.0__b77a5c561934e089/System.Data.SqlXml.dll----------------------------------------Infragistics2.Win.UltraWinSchedule.v9.2 Assembly Version: 9.2.20092.1003 Win32 Version: 9.2.20092.1003 CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Infragistics2.Win.UltraWinSchedule.v9.2/9.2.20092.1003__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinSchedule.v9.2.dll----------------------------------------System.Management Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Management/2.0.0.0__b03f5f7f11d50a3a/System.Management.dll----------------------------------------Infragistics2.Win.UltraWinCalcManager.v9.2 Assembly Version: 9.2.20092.1003 Win32 Version: 9.2.20092.1003 CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Infragistics2.Win.UltraWinCalcManager.v9.2/9.2.20092.1003__7dd5c3163f2cd0cb/Infragistics2.Win.UltraWinCalcManager.v9.2.dll----------------------------------------AFS.ERP.Pricing.Data Assembly Version: 4.1.297.297 Win32 Version: 4.1.297.297 CodeBase: file:///D:/AFS%20OMS/RELEASE/AFSERPWIN/WinUI/bin/Debug/AFS.ERP.Pricing.Data.DLL----------------------------------------AFS.ERP.Common.Data Assembly Version: 4.1.366.366 Win32 Version: 4.1.366.366 CodeBase: file:///D:/AFS%20OMS/RELEASE/AFSERPWIN/WinUI/bin/Debug/AFS.ERP.Common.Data.DLL----------------------------------------AFS.ERP.Deals.Data Assembly Version: 4.1.347.347 Win32 Version: 4.1.347.347 CodeBase: file:///D:/AFS%20OMS/RELEASE/AFSERPWIN/WinUI/bin/Debug/AFS.ERP.Deals.Data.DLL----------------------------------------AFS.ERP.GeneralLedger.WinUI Assembly Version: 4.1.622.622 Win32 Version: 4.1.622.622 CodeBase: file:///D:/AFS%20OMS/RELEASE/AFSERPWIN/WinUI/bin/Debug/AFS.ERP.GeneralLedger.WinUI.DLL----------------------------------------AFS.ERP.Common.WinUI Assembly Version: 4.1.576.576 Win32 Version: 4.1.576.576 CodeBase: file:///D:/AFS%20OMS/RELEASE/AFSERPWIN/WinUI/bin/Debug/AFS.ERP.Common.WinUI.DLL----------------------------------------AFS.ERP.SystemAdmin.WinUI Assembly Version: 0.0.0.0 Win32 Version: 0.0.0.0 CodeBase: file:///D:/AFS%20OMS/RELEASE/AFSERPWIN/WinUI/bin/Debug/AFS.ERP.SystemAdmin.WinUI.DLL----------------------------------------Microsoft.VisualBasic Assembly Version: 8.0.0.0 Win32 Version: 8.0.50727.4927 (NetFXspW7.050727-4900) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll----------------------------------------mdfugmaa Assembly Version: 4.1.297.297 Win32 Version: 2.0.50727.4962 (win7RTMGDR.050727-4900) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll----------------------------------------_pmuufwc Assembly Version: 4.1.347.347 Win32 Version: 2.0.50727.4962 (win7RTMGDR.050727-4900) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll----------------------------------------
************** JIT Debugging **************To enable just-in-time (JIT) debugging, the .config file for thisapplication or computer (machine.config) must have thejitDebugging value set in the system.windows.forms section.The application must also be compiled with debuggingenabled.
For example:
<configuration> <system.windows.forms jitDebugging="true" /></configuration>
When JIT debugging is enabled, any unhandled exceptionwill be sent to the JIT debugger registered on the computerrather than be handled by this dialog box.
Even I got this Error, Unable to resolve
Hello Ishnant,
I am checking about the progress of this issue. Please let me know If you need any further assistance on this.
Could you please try to attach if possible a small sample project reproducing the above mentioned issue, I will be happy to take a look at it.
