Am trying to use ElementHost to host a XamDataCarousel in a WinForms project but am getting a compile error when all the required references are added to the project, type 'Infragistics.Shared.ResourceCustomizer' exists in both InfragisticsWPF4.v12.1.dll and Infragistics4.Shared.v12.1.dll.
The first dll is required for use of XamDataCarousel, the second is required by other (non-WPF) controls that we are using.
Any suggestions on how this can be overcome?
Thanks.
Works a treat. Thanks!
In order to avoid this conflict you should use Alias. On the following link you will find a tutorial of how to use alias.
http://blogs.msdn.com/b/ansonh/archive/2006/09/27/774692.aspx
I suggest you to use alias for Infragistics4.Shared.v12.1, set Aliases property to “ WinFormsShared”. Then the code of the form will looks like:
extern alias WinFormsShared;
using System;
using System.Collections.Generic;
WinFormsShared::Infragistics.Shared.ResourceCustomizer rc = Infragistics.Win.UltraWinTree.Resources.Customizer;
rc.SetCustomizedString("xxxxx", "New string for 'xxxxx' resource");
