I have seen this use crop up from time to time. Here is my "AS IS" code I hope it may help someone else Dim p As Primitive Dim primitivesToAdd As PrimitiveCollection = New PrimitiveCollection() Dim primitivesToRemove As PrimitiveCollection = New PrimitiveCollection()
Dim xAxis As IAdvanceAxis = Nothing Dim yAxis As IAdvanceAxis = Nothing
If uchartPersonChart.CompositeChart.ChartLayers.Count > 0 Then xAxis = CType(uchartPersonChart.CompositeChart.ChartLayers(0).ChartLayer.Grid("X"), IAdvanceAxis) yAxis = CType(uchartPersonChart.CompositeChart.ChartLayers(0).ChartLayer.Grid("Y"), IAdvanceAxis) If xAxis Is Nothing Or yAxis Is Nothing Then Return End If End If
Dim olayers As ChartLayerCollection = uchartPersonChart.CompositeChart.ChartLayers Dim icurrentLayerIndex As Integer = 0 Dim currentLayer As ChartLayerAppearance = olayers(icurrentLayerIndex)
For Each p In e.SceneGraph If uchartPersonChart.CompositeChart.Legends.Count > 0 Then If uchartPersonChart.CompositeChart.Legends(0).ChartLayers.Count > 0 Then Dim lineApp As LineChartAppearance = CType(currentLayer.ChartTypeAppearance, LineChartAppearance) Dim seriesCounter As Integer = 0 If Not IsNothing(p.Path) Then If UCase(p.Path) = "LEGEND" Then Dim oPoly As Polyline = CType(p, Polyline) If (TypeOf p Is Polyline) Then oPoly = CType(p, Polyline) If Not oPoly Is Nothing Then ' we found a polyline in the legend. let's replace it. ' get the centerpoint of the polyline ' get the correct icon Dim sym As Symbol = New Symbol() ' get the centerpoint of the polyline sym.point = New Point((oPoly.points(0).point.X + oPoly.points(oPoly.points.Length - 1).point.X) / 2, (oPoly.points(0).point.Y + oPoly.points(oPoly.points.Length - 1).point.Y) / 2) ' get the correct icon sym.icon = lineApp.LineAppearances(oPoly.Row).IconAppearance.Icon oPoly.PE.StrokeWidth = CInt(2.5) sym.PE = oPoly.PE primitivesToAdd.Add(sym) primitivesToRemove.Add(oPoly) End If seriesCounter = seriesCounter + 1 If (seriesCounter >= currentLayer.Series.Count And olayers.Count > icurrentLayerIndex + 1) Then icurrentLayerIndex = icurrentLayerIndex + 1 currentLayer = olayers(icurrentLayerIndex) If currentLayer.ChartType <> ChartType.GanttChart Then lineApp = CType(currentLayer.ChartTypeAppearance, LineChartAppearance) seriesCounter = 0 End If End If End If End If End If End If End If Next p e.SceneGraph.AddRange(primitivesToAdd.ToArray()) For Each p In primitivesToRemove e.SceneGraph.Remove(p) Next
Here is the sample
Maybe another possible approach could be if you are using ScatterLineChart. More details you could find in attached sample.
