355
Read-only (non EditMode) so that Column.Format string is applied
using NetAdvantage 2009.2.
Where is the EditMode property, I keep reading about in the forums.  I udnerstand that the Format property will not be applied to a field in Edit Mode.
using the UtraWinGrid Designer, I've set the Bands[0].Override.AllowAddNew = no, .AllowDelete = False, and .AllowUpdate = False.
I've also set every columns CellActivation = ActiveOnly
I all DateTime columns (bound to DateTime? properties) to have Format = "MM/dd/yyyy", Style = "FormattedText" and DataType = DateTime
The grid will only be used to display data to the user. They will need to select a row, but will never edit the information in any row.
WHAT I WANT
I want to be able to format columns declaritively.  I know I can do this manually in the InitializeRow event.
