I use the UltraListView in my project with the thumbnials settings. I want to reduce the amount of white space around the picture ot the list view item. Has anybody a solution for this problem.
Hello Alti,
I am checking about the progress of this issue. Please let me know If you need any further assistance on this.
A possible approach to achieve this might be by using a 'CreationFilter'.
You could read about it at the following link: http://help.infragistics.com/Help/NetAdvantage/WinForms/2011.1/CLR2.0/html/Win_Creation_Filter.html. Here are some topics from our community which could also help you: http://community.infragistics.com/forums/t/34485.aspx, http://forums.infragistics.com/forums/t/47561.aspx http://community.infragistics.com/forums/t/58186.aspx, http://community.infragistics.com/forums/t/9989.aspx and http://community.infragistics.com/forums/t/50234.aspx. The above approach is not so recommended, because it features element's resizing, creating or removing and could lead to some unexpected behaviors.
And could you please review the sample attached to this post and see if it meets your requirements. Please feel free to let me know if I misunderstood you or if you have any other questions.
