430
Summary caption nightmares - "Sum =" Wont go away
I currently have a custom format for a summary that when the value is zero it should display blank. Unfortunately I cant seem to get rid of the "Sum =" Ive tried modifying it on the summary change event of the grid and six ways from sunday inside the custom format. Code posted below:
In the init grid:
 .Summaries.Add(SummaryType.Sum, .Columns(PayAmount)).DisplayFormatProvider = New NumberFormatProvider
Class NumberFormatProvider
Public Class NumberFormatProvider
    Implements IFormatProvider, ICustomFormatter
    Public Function Format(format1 As String, arg As Object, formatProvider As System.IFormatProvider) As String Implements System.ICustomFormatter.Format
        Try
            If TypeOf arg Is Decimal Then
                Return HandleOtherFormats("$0.00", arg)
            End If
        Catch ex As Exception
            Throw ex
        End Try
    End Function
    Public Function GetFormat(formatType As System.Type) As Object Implements System.IFormatProvider.GetFormat
        If formatType Is GetType(System.ICustomFormatter) Then
            Return Me
        Else
            Return Nothing
        End If
    End Function
    Private Function HandleOtherFormats(fmt As String, arg As Object) As String
        If TypeOf arg Is IFormattable AndAlso arg <> 0 Then
            Return DirectCast(arg, IFormattable).ToString(fmt, Me)
        Else
            Return ""
        End If
    End Function
End Class
Please help!
