475
How do I clear chart data for a re-plot?
I have a panel where the user selects a date range for data to plot on a scatter chart and presses a command button to refresh the chart. Once I have show data for the first time the chart does not want to clear to show new data, it always shows the original data and does not refresh. How do I get it clear its old data and show the new. Here is what I have tried.
            Dim gSeries As Infragistics.UltraChart.Resources.Appearance.NumericTimeSeries
            chartData.DataBindings.Clear()
            chartData.Series.Clear()
            chartData.BeginInit()
            While stk.Count > 0
                rw = stk.Pop
                If fGetSQLData(dtStartDate.Value, dtEndDate.Value, rw("CustId"), cboProduct.Value, cboGraphVal.Text) Then
                    '== Check to see if there was any actual data for this customer
                    If tblSQLData.Rows.Count = 0 Then
                        MsgBox(rw("CustName") & " did not contain any data within the date range you selected", MsgBoxStyle.Information, "No Data For Customer")
                    Else
                        gSeries = New Infragistics.UltraChart.Resources.Appearance.NumericTimeSeries
                        gSeries.DataBind(tblSQLData, "Date", cboGraphVal.Text)
                        chartData.Series.Add(gSeries)
                    End If
                End If
            End While
            chartData.DataBind()
            chartData.EndInit()
            chartData.Visible = True
  • 475
    Verified Answer
    Change this...
    To This...
      chartData.DataSource = Nothing
  • 53790
    Hello wltaylor,
    Our chart just represent your data that you apply to UltraChart`s DataSource, So if you make a changes in your DataSet, then our UltraChart will represent the changes in the graphics. Looking at the provided code, I`m not able to reproduce your issue, so if you are able, please send us your sample with your issue and I`ll be glad to research this issue for you.
    Regards
