1060
Can I (or should I ) use the gauge to do this
I was asked to develop a dashboard using a gauge that would look like this
The size of each of the four area would be dynamic and filled at runtime from a 5 column record
Name  Green Yellow  ORange Red
Fred     30%    25%     25%      20%
Technically I would like to label the values on the color area and also put the name in the ark
Is this doable ?
  • 53790
    Verified Answer
    Hello Fred,
    Maybe you could achieve desired behavior if you are using our UltraGauge control. You could used our Presets or if you want you could create your own gauge. You could do this using Gauge`s designer or through code:
    Please take a look at the attached video, where is shown how to modify existing gauge.
