944
Customizing Grid Summaries
In the grid below I have used Summary by DataType, so the Sequence column and all of the Original and Revised Amount columns are totalled to the bottom of the Grid.
Grid summary
Now, I was able to hide the Sum sign on the Sequence column header, but I actually dont want the Sequence column to have a summary at all. How can I remove this one.
Also, is it possible to remove the 'Sum = ' from each column summary and only have the totalled value.
Can I format the summary? ie halign...I would like these to be right alighed like the columns above them. I also need to format the calculated value to only have 2 digits after the decimal place.
Many thanks
Jason
