Hi there,
is it possible to use the Drag&Drop Funcion with the UltraToolBarsManager? First i did it with the UltraTree using the DoDragDrop-Function but this one does not exist on UltraToolBarsManager.
What must i do to use Drag&Drop with the UltraToolBarsManager?
regards
Cloud
actually i did not solve my probem. i do not understand how to solve this so i will not do it with drag&drop
Hello Cloud,
Have you been able to resolve your issue ? If you still have any concerns or questions I will be glad to help. If you need any additional assistance don’t hesitate to ask.
Regards
At that moment we didn`t implement drag & drop functionality in our UltraToolbarManager. If you want to achieve such behavior, you could handle few events (see the list below) and implement there your custom code. The events are:
ultraToolbarsManager1_MouseEnterElement()
ultraToolbarsManager1_MouseLeaveElement()
ultraToolbarsManager1_ToolbarModified()
if you want to use both events:
ultraToolbarsManager1_BeforeToolDragBegin()
ultraToolbarsManager1_AfterToolDragEnd()
please note that they firing when this Customize window is opened. The 'Customize' feature lets you organize the toolbars to suit your special needs like positioning certain tools at certain visible indices. You could find more information about these events in our online documentation
http://help.infragistics.com/Help/NetAdvantage/WinForms/2011.1/CLR2.0/html/Infragistics2.Win.UltraWinToolbars.v11.1~Infragistics.Win.UltraWinToolbars.UltraToolbarsManager~BeforeToolDragBegin_EV.html
http://help.infragistics.com/Help/NetAdvantage/WinForms/2011.1/CLR2.0/html/Infragistics2.Win.UltraWinToolbars.v11.1~Infragistics.Win.UltraWinToolbars.UltraToolbarsManager~AfterToolDragEnd_EV.html
the question is really simple:
does the ultratoolbarsmanager have a simple way to start the drag&drop with a button tool?
that´s not the problem. i just need to know how can i do something like the DoDragDrop-Function on the ultratoolbarsmanager where i can save a bunch of data that i can use in the dragdrop-event on the explorerbar...
