We are trying to add ribbon Quick Access Toolbar customization functionality and are attempting to use the RibbonCustomizationProvider dialog for that. We have encountered a few issues with this however:1) An exception occurs when removing all of the tools from the right pane (Quick Access Toolbar tools). This also occurs in the "Ribbon Customization" sample. Is there a workaround this issue, except handling this exception ourselves?
2) All of the ribbon tools are added to the RibbonCustomizationProvider including the '&' symbols which are included with some of the ribbon commands for shortcut key capabilities. Is there a way to remove this characters?
Thank you! :)
Thanks for that!
Awaiting your reply
Hello ,
I have created three support tickets for you with ids: CAS-95082-9W47YG, CAS-95186-JTNBW and CAS-95189-8GBGWL, in order to investigate your issues further for you. I will update you for the progress of those issues via the cases as soon as I have information for you.
