Hi, I am adding two controls at run time in DockableGroupPane and then adding that in DockManager. I am getting the result as below
Which is correct behavior. BUT when I add only single control the dockmanager does not create a single tab, instead it does not create any tab. Please refer the below image
Can someone please let me know how can I achieve single tab if I add only 1 control and two tabs if I add 2 controls. Below is the code I am using to add
private void Form1_Load(object sender, EventArgs e)
SuspendLayout();
DockableControlPane dcpTreeView =
new DockableControlPane("tree", "Tree View", this.treeView1);
DockableControlPane dcpListView =
new DockableControlPane("list", "List View", this.listView1);
DockableGroupPane dgpTreeList = new DockableGroupPane();
dgpTreeList.ChildPaneStyle = ChildPaneStyle.TabGroup;
dgpTreeList.Panes.Add(dcpTreeView);
dgpTreeList.Panes.Add(dcpListView);
DockAreaPane dapLeft = new DockAreaPane(DockedLocation.DockedLeft);
dapLeft.Panes.Add(dgpTreeList);
this.ultraDockManager1.DockAreas.Add(dapLeft);
ResumeLayout();
ajayk2k1 said:Can someone please let me know how can I achieve single tab if I add only 1 control and two tabs if I add 2 controls
At that moment we didn`t implement such kind functionality, but maybe one possible way to achieve desired behavior could be if you are using additional control (for example UltraLabel) and set the property TabWidth = 1. Please take a look at the attached vidoe and sample for more details and let me know if you have any questions
Regards
